So am I correct to assume that APPX is for GPS Sync radios and SMPX is for non-GPS Sync radios ?
After upgrading SM's Tools> Software Uprade says: "Software Version Not applicable" instead of 2.6.1 or whatever I would expect it to say. Assuming this is normal since it says this on every single radio I upgraded to 2.6.1
When can we expect 2.6.1 final? We have several AP's affected by this, and I would rather wait until the final release (which is due this week?) to come out before upgrading.
Also - should I have a problem upgrading AP's and SM's from 2.3.1 and 2.4.1 straight to 2.6.1?
do a reboot before you put the upgrade. What's i see when the ap start to glitch that's affect alot of thing random in the AP before they get a kernel panic and reboot by itself
I think you're a bit optimistic - unless I read things wrong, the hope is that the public beta will be available later this week, NOT the final release.
So I have been able to install 2.6.1 on several of MY APs many of the issues have been resolved.
The problem I'm still having is APs that won't even begin to boot. The Ethernet goes up and down every few seconds, but never fully boots. I grabbed two new APs, installed 2.6.1, and replaced the two I was having prblems with. SAME THING!! I know it can take up to 20 minutes, but after an hour they never booted.
As a last ditch I unplugged the radios from the CMM and plugged them into the power supply that came with the APs and eventually they booted..
Any thoughts on why the CMM Micro won't boot the radios, but the PSU will??
We did try rebooting them. We were able to finally get the few that were having this issue to take the new firmware after powering them down completely a few times.
Check the voltage output on your CMM,, the Cambium AP datasheet states 23-56 volt, but I think some of the sync injectors run close to that 23 volt, so you may have some voltage loss on your cables depending on length, etc.
Also I'm wondering if when first booting up it's turning the heater inside the AP on and possibly drawing more power than what your injector is supplying.
We have seen this with using Mikrotik powerboxes to power them and eventually they do boot, possibly the heater is done warming the chipset and no longer creating extra power draw?
ePMP Beta Release 2.6.1-RC5 is now available. This release addresses the cold issue along with a few other critical bug fixes. This release is compatible with all ePMP radios similar to 2.6.1-RC1 that was posted earlier in this thread.
This crash is not related to cold and it is software induced. We're investigating this crash as our top priority issue. We hope to have a fix for this soon. If your radio is not impacted by the cold issue, you can downgrade to 2.5.2 to avoid this crash.
