Hello,
I have the same issue with more than 4 E410 devices here.
Appreciate your help aswell.
Hello,
@jiransi - update the firmware of the unit and it should work.
I had that problem last week and by updating the firmware to the latest version it solved the pending status
The problem with my E4100 is that when i tried to claim it, it never seems to be onboard.
Message i got was "Waiting for Device" but nothing changed after that.
So i never get to get the device onboard and update the software.
Appreciate your help.
Hello there,
I have the same problem... my cnpilot cnPilot-BC1DB2 status:
TypeSerial NumberDeviceMACIP AddressAdded ByStatusDurationConfigure
cnPilot
cnPilot-BC1DB2 |
N/A |
Serial Number
Waiting for Device |
0d 1h 52m |
I have the same problem with epmp3000 AP , Radio link function OK , still show offline status on our On-Premises cnmaestro , already tried factory reset , delete and add , upgrade / downgrade firmware , but still fail .
I need help regarding the onboard device. I have more than 5 cnPilot E410. It is on pending status.
