Hi Shawita,
I am sorry, but due to technichal issues we were not able to record it.
Dmitry
Hi Shawita,
Dmitry
Thanks Ray / Dmitry.
On the 3rd slide, can you explain:
• 80+80 operation(Not applicable to F300),
• Non contiguous channel bonding (Not applicable to F300)
I get the 300 doesn't do 80+80, but it does 40+40 right? And it doesn't do non-contiguous bonding? What's the point of 40+40 in this scenario - isn't it the same as wave 1 80mhz?
Maybe I misunderstood?
Rich
Hi richinuk,
In the 802.11ac standard there is 80+80MHz non-contiguous mode, but we don't support it on Force300.
There is no such thing as 40+40MHz in the standard. So with Force 300 you have the following channel options: 20/40/80MHz.
With PTP550 you will have an option of assymetric non-contiguous modes(eg 20+80MHz).
Dmitry
Whould it be possible to reschedule a new webinar for all of us that didn't have the chance to attend it the first time?
@Dmitry Moiseev wrote:Hi richinuk,
Dmitry
Thanks Dmitry. I must have missed that and got confused with the PTP550 features. :(
That's a real shame. It would be killer for the E3K to support non-contiguous channels, and assymetric ones at that!
Rich
Hi vmiskos,
We can do one more webinar, stay tuned for the date.
Dmitry
That's a good idea!!
Dmitry already said there will be another webiner soon
Did the webinar actually take place? My system kept on saying waiting on the Presenter. If it did, was the webinar recorded to be viewed by us at a later time? When will the presentation be available?
Regards.
You can view the recording here. Please post your questions and comments to this thread. We will post the slides soon.
The audio says the force 300's are shipping now. Do you know anyone who has them available in Canada?
There is a feature brought up regarding 80+80, is it safe to say the 3k itself will have this ability?
What’s the update for 3k release? The entire product line is way behind schedule.
can you give us right now phisical dimensions of new 4x4 sector antenna !
Thx
@Makoto wrote:
Thx
Hi Makoto,
The dimensions of antenna are 596x246x86mm.
Dmitry
No, there will not be 80+80 operation on e3k. What we see from the field that it is very hard to find even one clear 80MHz channel so 80+80 sounds impractical especially taking into consideration CINR requirements to get descent throughput.
We are planning to have e3k this summer.
Yes, they are shipping now. Please ask your local distributors on the availability:
