Good afternoon, I'm building a network where it has two SSIDs, I configured the two networks, but only one of them is being transmitted in 2.4Ghz and the other transmits only in 5.8Ghz. I am using a vlan for the second SSID, the firmware of the radio is with 3.2.1-r6, cnPilot E400 radio.
Under WLAN configuration there is a setting called radios. It defaults to 2.4+5GHz. Could you please check if you happen to have them set to that value (or is one set to 2.4 and the other set to 5GHz)?
Both ssid are 2.4 + 5.8Ghz
Is it feasibile to provide a remote access to debug and fix the issue.
Solved, I downloaded the 2.4Ghz radio channel, from 40Mhz to 20Mhz, so the other SSIDs started to be transmitted in 2.4Ghz
Thank you for the update.
