cancel
Showing results for
Search instead for
Did you mean:
Re-Use Existing Antennas for PTP820
SOLVED
Moderator
Capture.JPGYou can find the REMEC adaptor and Dragonwave adaptor installation guide attached or download from Cambium support web page.
Here is a list of all SKUs availble:
N060082L004A
PTP 820 Andrew Valuline Antenna Convert kit, 6GHz
N070082L003A
PTP 820 Andrew Valuline Antenna Convert kit, 7GHz
N110082L003A
PTP 820 Andrew Valuline Antenna Convert kit, 11GHz
N130082L003A
PTP 820 Andrew Valuline Antenna Convert kit, 13GHz
N150082L001A
PTP 820 Andrew Valuline Antenna Convert kit, 15GHz
N180082L001A
PTP 820 Andrew Valuline Antenna Convert kit, 18GHz
N230082L001A
PTP 820 Andrew Valuline Antenna Convert kit, 23GHz
N260082L001A
PTP 820 Andrew Valuline Antenna Convert kit, 26GHz
N280082L001A
PTP 820 Andrew Valuline Antenna Convert kit, 28GHz
N320082L001A
PTP 820 Andrew Valuline Antenna Convert kit, 32GHz
N380082L001A
PTP 820 Andrew Valuline Antenna Convert kit, 38GHz
N110082L004A
PTP820 Radiowave Antenna Conversion kit  Exalt -> Cambium, 11 GHz, 2ft
N110082L005A
PTP820 Radiowave Antenna Conversion kit  Exalt -> Cambium, 11 GHz, 3ft
N110082L006A
PTP820 Radiowave Antenna Conversion kit  Exalt -> Cambium, 11 GHz, 4ft
N110082L007A
PTP820 Radiowave Antenna Conversion kit  Exalt -> Cambium, 11 GHz, 6ft
N180082L002A
PTP820 Radiowave Antenna Conversion kit  Exalt -> Cambium, 18 GHz, 2ft
N180082L003A
PTP820 Radiowave Antenna Conversion kit  Exalt -> Cambium, 18 GHz, 3ft
N180082L004A
PTP820 Radiowave Antenna Conversion kit  Exalt -> Cambium, 18 GHz, 4ft
N180082L005A
PTP820 Radiowave Antenna Conversion kit  Exalt -> Cambium, 18 GHz, 6ft
N110082L008A
PTP820 Radiowave Antenna Conversion kit  Dragonwave -> Cambium, 11 GHz, 3ft
N110082L009A
PTP820 Radiowave Antenna Conversion kit  Dragonwave -> Cambium, 11 GHz, 4ft
N110082L010A
PTP820 Radiowave Antenna Conversion kit  Dragonwave -> Cambium, 11 GHz, 6ft
N180082L006A
PTP820 Radiowave Antenna Conversion kit  Dragonwave -> Cambium, 18 GHz, 3ft
N180082L007A
PTP820 Radiowave Antenna Conversion kit  Dragonwave -> Cambium, 18 GHz, 4ft
N180082L008A
PTP820 Radiowave Antenna Conversion kit  Dragonwave -> Cambium, 18 GHz, 6ft
N060082L162A
PTP820 Radiowave Antenna Conversion kit  Dragonwave -> Cambium, 6 GHz, 6ft
N110082L011A
PTP820 Dragonwave Antenna Adaptor for Cambium, 11GHz
N130082L004A
PTP820 Dragonwave Antenna Adaptor for Cambium, 13GHz
N180082L009A
PTP820 Dragonwave Antenna Adaptor for Cambium, 18GHz
N230082L002A
PTP820 Dragonwave Antenna Adaptor for Cambium, 23GHz
N060082L217A
PTP820 REMEC interface Antenna Adaptor Kit, 6 GHz, Single Pol
N110082L125A
PTP820 REMEC interface Antenna Adaptor Kit, 11 GHz, Single Pol
N180082L062A
PTP820 REMEC interface Antenna Adaptor Kit, 18 GHz, Single Pol
N110082L126A
PTP820 REMEC interface Antenna Adaptor Kit, 11 GHz, Dual Pol
N180082L063A
PTP820 REMEC interface Antenna Adaptor Kit, 18 GHz, Dual Pol
N230082L070A
PTP820 REMEC interface Antenna Adaptor Kit, 23 GHz, Dual Pol
New Contributor
Re: Re-Use Existing Antennas for PTP820
Allen,
So if a project calls for re-using existing RW dishes, but we want a remote mounted radio, what parts would be required for converting from Dragonwave radios? Speciffically on the antenna side.  I know the PTP820 Remote
Mount kits.
Jeff
Moderator
if the antenna provide standard flange, we can always go with remote mount for PTP820, then use flexible waveguide to connect PTP820 radio to the antenna port.
Here is a list of SKUs you may need for PTP820 Remote mount
The PTP820S and PTP820G RFU-C share the same mount bracket. For 6-13 GHz, an adaptor is required as the Radio flange is proprietary.
N060082L003A PTP 820 RFU-C ADPT 6GHz Remote Mount Adpator - UDR70
N070082L002A PTP 820 RFU-C ADPT 7_8GHz Remote Mount Adaptor - UBR84
N110082L002A PTP 820 RFU-C ADPT 10_11GHz Remote Mount Adaptor - UBR100
N130082L002A PTP 820 RFU-C ADPT 13GHz Remote Mount Adaptor - UBR120
N000082L121A PTP 820 RFU-C Pole Mount kit
N000082L120A PTP 820C DC REMOTE MOUNT KIT
N060082L002A PTP 820C 6G  Remote Mount adaptor - UDR70
N070082L001A PTP 820C 7-8G Remote Mount adaptor - UBR84
N110082L001A PTP 820C 10-11G Remote Mount adaptor - UBR100
N130082L001A PTP 820C 13G  Remote Mount adaptor - UBR120
Regards
Allen
New Contributor
Allen,
Two Last questions.  What is the difference between the Adaptor Kit and the Conversion Kit.  (the drawings are a little unclear) Are both needed to change a SP RW DW antenna into a DP RW antenna for use with a PTP820C?
Jeff
Moderator
For adaptor, you really don't need to do any change on antenna. You just need add the adaptor, then add the PTP820 radio.
When use converter, you basically need remove the old plate and replaced with the new converter.
From performance point of view, there is no real difference.  You only need one of them. Personally i prefer to use converter than adaptor. As converter make the antenna more like the direct mount PTP820 dish. The adaptor is a add up, it add extra weight to the antenna.
Regards
Allen
New Contributor
Perfect!  Excellent explaination.
Thank You,
Jeff
Cambium Employee
Do these conversion kits also work with any existing Radomes present on the antennas?
Contributor
I have several Trango Apex Plus 11 GHz links, one of which has the Trango branded 3 ft dishes which perform well but are big suckers (kind of a deep parabolic design I think).  I desperately need more throughput on this particular link, which is also fairly long, and I was figuring I would have to switch to 6 GHz, take down the Trango monster dishes, and put up new ones.  But in Link Planner, it doesn't look like 6 GHz is light years better than 11 GHz on this link.
So does this mean I could use the Remec adapter to reuse the Trango dishes with PTP820S radios?  (Of course I would have to go through PCNs and license modification.)  Has anybody done this, and is the performance as calculated?
One more question:  why are there different adapters for single and dual polarization?
Moderator
"why are there different adapters for single and dual polarization?"
Wouldn't customers be a little skeptical if we offered a one-size fits all adapter?
If the link is single polarization (V or H), it needs a single pol adapter.
If the link is dual polarization (Cross-pol or XPIC, ACAP or CCDP), it needs a dual pol adapter.
Please let me know if I've misunderstood your question!
Thanks for using the forum!
Dave
Moderator
Please check "PTP 820 REMEC Adaptor Installation Guide" under PTP820 support web page.
It listed what kind of antenna and configuration can use the REMEC adaptor.
Regards
Allen
