Hi all,
2 sites are 100km over sea water, LOS. Just used Simulation tool, using PTP 600 Series Lite Connectorized and Andrew Parabolic antenna, the result shows that Availability is over 99%. Anyone is running the same link in reality? Please share your comments, experiences about the feasibility.
Thanks in advance
Phuong
I have many 80-90 km links, but most of them are with BH10s and 20s. They are from hills to plain land. I dont have experience over water but if the two points are high enough so that the fresnel zones are also clear of water, you should be fine.
Hai,
Have you tried the link over sea? what is the result?
We need to connect two island for a distance of about 52 Kms. Pls suggest your idea. We need minimum of 50 Mbps
Balaji
