I know on the spec sheet that i last looked at, it stated that the epmp 2000 is on the roadmap for compatibility.
When is that supposed to come down the pipe?
Hi John,
We are currently working on ePMP 2000/CMM5 compatibility, but I'm not sure when it will be fully implemented.
I’ll try to get you a more specific answer. If I can, I'll post it here.
All The Best,
Tyler
correct me if im wrong
epmp 2000 support all previous CMM's
and now CMM5 comes out after epmp2000 and is not supported ?
that can't be real can it ?
