CMM4 GPS Info
Should a PMP450 AP show GPS information when recieving sync from a CMM4 like it does when using a UGPS.
Hello Tom,
CMM4 does not send any GPS information to AP. So behavior you are seeing is correct.
When AP is connected to uGPS it also receives GPS information from uGPS which is then displayed on the GUI.
Dhaval
Thanks!
