Hi everyone my WIMAX isp installed a PMP 450 SM 5GHZ directly plugging it into a 20$ Zyxel router (seems there is not cambium AP between zyxel and the 450SM), which is horrible in routing and connection stability.
-Zyxel router had obscured password, so i can't retrieve the wan IP of the 450SM
-Tried bypass the Zyxel plugging my old router (better one) but nothing, (i guess dhcp disabled from 450SM if there is one)
-The default SM IP address i found on the manual has also been changed.
Is there anything i can do in order to switch that tedious Zyxel for my old Router?
