I’ve 2/3 radios with these error logs, they cannot register to any APs.
System Startup
System Reset Exception – Watchdog Reset Cur ExtInt 0 Max ExtInt 0 Cur DecInt 0 Max DecInt 0 Cur Sync 0 Max Sync 0 Cur LED 2 Max LED 1 Cur WDOG 0 Max WDOG 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 0 Max FEC 0 Cur FPGA 0 Max FPGA 0 Cur FrmLoc 0 Max FrmLoc 0 Cur WatchDog 33 Max WatchDog 33 RTMLogStats 0 AAState 0
Software Version : CANOPY 13.2.1 SM-DES
Board Type : P11
Device Setting : 5.4/5.7GHz MIMO OFDM - Subscriber Module - 0a-00-3e-b2-10-db
Default plug overrides configured parameters
FPGA Version : 081514
FPGA Features : DES, Sched;
01/01/2011 : 01:06:35 UTC : :XO trim at max diff=4572 c=63 cmove=31 f=8191 fmove=-78
01/01/2011 : 01:06:36 UTC : :XO trim at max diff=6367 c=63 cmove=43 f=8191 fmove=-83
01/01/2011 : 01:06:37 UTC : :XO trim at max diff=6366 c=63 cmove=43 f=8191 fmove=-84
01/01/2011 : 01:06:38 UTC : :XO trim at max diff=6368 c=63 cmove=43 f=8191 fmove=-82
01/01/2011 : 01:06:39 UTC : :XO trim at max diff=6368 c=32 cmove=43 f=8174 fmove=-82
01/01/2011 : 01:06:40 UTC : :XO trim at max diff=6369 c=63 cmove=43 f=8191 fmove=-81
01/01/2011 : 01:06:41 UTC : :XO trim at max diff=6369 c=63 cmove=43 f=8191 fmove=-81
01/01/2011 : 01:06:42 UTC : :XO trim at max diff=6369 c=63 cmove=43 f=8191 fmove=-81
01/01/2011 : 01:06:43 UTC : :XO trim at max diff=6370 c=63 cmove=43 f=8191 fmove=-80
01/01/2011 : 01:06:45 UTC : :XO trim at max diff=6370 c=63 cmove=43 f=8191 fmove=-80
01/01/2011 : 01:07:44 UTC : :Reset due to error setting receive frequency 5775 at temperature 55 C
01/01/2011 : 01:08:44 UTC : :Forced reset;
01/01/2011 : 01:08:44 UTC : System Startup
@NW_WISP wrote: I've 2/3 radios with these error logs, they cannot register to anyAPs.
******System Startup******
System Reset Exception -- Watchdog Reset Cur ExtInt 0 Max ExtInt 0 Cur DecInt 0 Max DecInt 0 Cur Sync 0 Max Sync 0 Cur LED 2 Max LED 1 Cur WDOG 0 Max WDOG 1 Cur EthXcvr 0 Max EthXcvr 1 Cur FEC 0 Max FEC 0 Cur FPGA 0 Max FPGA 0 Cur FrmLoc 0 Max FrmLoc 0 Cur WatchDog 33 Max WatchDog 33 RTMLogStats 0 AAState 0
Board Type : P11
NW_WISP,
This error could can happen on occasion, but it if is happening every boot then it is a hardware failure. Support should be contacted for RMA process.
