Cable Diagram for 450i and 450m to UGPS
This cable will allow you to power a UGPS module from a 450i or 450m, while receiving GPS positional data and 1PPS sync.
Software Configuration
The 450i must have the following settings configured:
General Config Page --> Sync Source --> AutoSync or AutoSync + Free Run
UGPS Power --> Enabled (optional if providing power from another source)
Pins and Functions
Function
450i Aux Port Pin (RJ-45)
UGPS Sync Port Pin (RJ-12)
UGPS Power
4
4
Rx GPS Data
5
3
Ground
7
6
1PPS Sync
8
1
Note: The maximum cable length for this application is 35m (120 ft.), but it is highly recommended to restrict this cable to 10m or less.
Update:  10m is the maximum recommended cable length for this type of cable.
It can work up to 40m, but it is highly recommended that you restrict the cable length to 10m.
If the cable is greater than 5m in length, it is recommended that surge suppression is used.
Another note is to ensure that the 6-pin cable connectors are suitable for solid wire conductors (Ethernet type cables).  If the connectors are intended for stranded cables, they may not work reliably with solid wire cables, and can result in latent issues.
