I've reached out to our radio vendor / supplier, but they seem at a loss, so I was hoping someone out in Cambium-land can advise: we are installing a few PTP 450 900 SMs at a couple of industrial sites. The power supplies shipped with these units are AC in / 30V DC out. Out standard in the field is usually 24VDC, or in some cases, 12VDC and/or 12VDC power. Has anyone run across a standard 24VDC in / 30VDC out power supply, for use with these radios? Unfortunately, I cannot use standard POE/POE+ supporting power supplies, since they support a higher VDC output. I wish Cambium had thought this through, instead of worrying about backward compatibility with the 100 series power supplies
Alternatively, I can use a Meanwell 24VDC adjustable output power supply to power / ground pins 4,5,7,8, but I don't see any literature that documents this approach, so that I don't have to worry about inadvertently destroying a PTP 450 900 in the process.
K Rather
