Hi Guys, have you tested these switches?
Do you know if they can power ptp600 or ptp650?
Totally.
Here’s the link to the right one.
Link:
https://www.netonix.com/ws-6-mini.html
Remember PTP 600 works at 56VDC. It will be good enough with the 2A Top, netonix switches already handle it.
Best Regards.
Kevin Cedeno F.
NPO and EPC Wireless Engineer
EWPE - Ericsson LTE Certified Engineer
MWFE - Motorola Wireless Field Engineer
Landline: +593 97-952-2253
Mobil WS : +593 98-896-8995
Landline EUA: +1 (518) 712-9466
Ecuador - Guayaquil
United States - California
Unless you try to do something beyond what you have already mastered, you will never grow.
Gracias Kevin,
Donde trabajas en Guayaquil?
Hello Kevin
Will netonix power the PTP650 radios? or only the 650?
Tnx
Netonix will not power ptp600/500. these radios only work with PIDU+ and metalic LPU.
