I have a link with a PTP 550 with 4.1.1 version using 40 Mhz of bandwith, the problem is that the I do not Know why We are having problems with some webpages and with the upload traffic, for example imposible use the skype program, imposible attach files to email, imposible make a speed test in some pages (in some yo can make speedtest, in others no) is like the device discard traffic and mostly traffic of upload. What could be the problem?
yes, We installed in the tower for provide service to clients, but We had to change for other ptp because We could not find a solution and clients were complaining, now We have these devices checking in the office, We are trying with channel bonding, without channel bonding, in 20 Mhz, 40 Mhz and 80 Mhz of bandwith, in other country, in our country region too, swapping master-slave, but We have the same problem, problem with upload traffic. Always checking with a pppoe connection like our clients have, and the weird thing is that if we try with dhcp connection We have not the problem with upload traffic, is very curious, is like may be mtu problems, ptp has set size of mtu 1538, and our pppoe have 1492, and we connect the ptp in cisco switches with 1500 mtu size, so We donot know which is the problem.
I tried to get a diagnostic file, with x.x.x.x/field_diags.cgi being x.x.x.x the ip address of the device but is impossible get it.
Hi, Did you happen to solve your issue regards this - curious because we also have PPPoE clients and we are also seeing issues on the PTP550 with traffic issues for some reason. I cant quite seem to work out what the issue is and was wondering if you ever had any feedback?
Do these issues go away when you use single channel mode (i.e. turn off bonding)?
We cannot solve the problem, We tried many solutions, change mtu in the server and in the client and seems that the problem is the same, We upgrade the ptp to the las version, that allow change mtu in the ethernet and we are getting the same problem
So again... second time I've asked... are you using bonding or not? What happens when you use a single, 20MHz carrier on the cleanest channel you can find?
We just installed a couple of ptp550. We are using 20/25 vlan. ONE of them have the same problem: it's working on layer 2 (i can see mac address), ping is ok, traceroute is ok, dns are ok. But when try to load ANY page it's alway "connecting". All other vlans seems working fine as expected.
ptp550 with a very simple configuration: 40mhz, fw 4.1.3 and 4.1.4-BETA, no bonding. data vlan disabled, one management vlan.
PS with previous BH everithing was ok, it not a configuration problem.
Featuring the same problem. The scenario is for pppoe authentication. In two vlans it works normally. In others the pppoe connection is established, but navigation does not work. Ping works normally, but it does not browse, no other port works, either 53 or 22. All settings (mtu, inclusive) have been reviewed and the problem has not been resolved.
Is the same using bonding or not, 20 Mhz or 40 Mhz. Now We have the ptp in the office because We still facing the problem with traffic pppoe so We cannot use it for clients, and We are trying with different settings, just now in 20 Mhz without bonding and still having the problem, overall with upload traffic. Using the last version 4.1.4. Could someone solve this problem?
Hi Andrii, can Cambium comment on when they expect to put a fix out?
I'm sure ISP's out there using this gear and have in place servicing customers (myself included) would appreciate an update / explanation of issues and possible timeframes of new releases. I'm sure others would be happy to help as I'm sure plenty of others would be with any required testing, data dumps, etc so we can make it a better product for everyone.
