cancel
Showing results for
Search instead for
Did you mean:
Advanced Troubleshooting Options for ePMP from cnMaestro Cloud and On Premises Servers
Moderator KR
Moderator
This document Outlines about the Advanced Troubleshooting Options for ePMP from cnMaestro Cloud and On Premises Servers.
Cnmaestro has provision to run the Link Test and eDetect Options from the version 1.4.0 which can be used for troubleshooting the Link related issues wrt Throughput and Interference .
Link Test :-
Link Test can be performed on ePMP AP or SM. In order to run this operation select the device on which you want to run this operation in the Tree and select the Tools option from the Monitor Menu.
If an ePMP AP is selected you can select the required SM from the drop down and  start the test. If an ePMP SM is selected , please click the Start Test to run the link test.
Once the test has run the results  will be shown in the same page where the test was run.
User can select different packet sizes and Duration intervals and can run the test to see the Link Test Results.
eDetect :-
eDetect can be performed on ePMP AP or SM. In order to run this operation select the device on which you want to run this operation in the Tree and select the Tools option from the Monitor Menu.
Select the Duration for which the test should run and clikc on the Start Test.
Once  the operation is completed the interfering device details will be shown in the same page where the test is started.
These results will show what is the MAC address of the Interfering device and RSSI and MCS values of the interfering device .
