Is it on the road map to be able to scan epmp into cnmaestro?
I will check and confirm soon.
We don't have a scanner in cnMaestro to automatically onBoard ePMP, but you can use the following method to automatically onboard ePMP and other cambium units:
Dmitry
Additionally, for new installs, the installer app can be used to automatically onboard your SMs into cnMaestro (and always captures the SM's lat/long as well).
https://www.cambiumnetworks.com/products/management/cnarcher/
cnArcher will support ePMP (and iOS) near the end Q2.
So for the dhcp way I would need to have a cnmaestro server set up localy it won't work with the cloud version?
Yes DHCP option will work with On-Premises version of cnMaestro only.
We dont support DHCP for cloud as by default device communicates with cloud.cambiumnetworks.com
