The data usage graph for SM issue i tried to reproduce on both Cloud as well as on Premises servers but i am unable to reproduce it. The data points are correctly shown. If you dont mine can you on board any other AP and SM or SM alone and check whether the issue is occuring int hat new device also. If the issue is seen in the new SM also i will raise a bug and ask our engineering team to look into the same.
Is it just a matter of mislabelling the dates? A time correlation error? How much? I know there was an issue with time before - Local -vs- UTC. Is this still the case?
The data doesn't mean much without some kind of explanation.
I know you can't fix it on the fly, but if you could tell me how to read the graph; it would be a great help.
Thanks for your patience. This is a bug in the current UI. The day's data aggregation for the bar chart happens over an UTC day rather than the users local time. We will try to prioritize this in our upcoming release.
Still not addressed in 1.5.1 OP - Doesn't appear to be just a matter of time zone diffrence. The correlation is a full day off - We are at UTC - 5 data is being displayed a day earlier. If anything, the displayed data should be a day later not earlier.
Other data is likewise incorrect. Alarms reports show raised time as local , cleared times as UTC duration is correct.
Again , it makes it difficult to trobleshoot.
cnMaestro works pretty well as a realtime management platform, but not so much as a reliable historical data collection/utilization or trobleshooting tool.
