cancel
Showing results for
Search instead for
Did you mean:
CNPilot E410 in bridge mode
SOLVED
Contributor
Hi! I'd like to know where do I change the cNPilot E410 to bridge mode? It will be linked to an ISP modem/router so do I need to configure SSID and password in radio or just in the modem?
1 REPLY
Moderator
Re: CNPilot E410 in bridge mode
Bridged mode is the default. Simply configure a WLAN with the SSID and WPA password on the E410.
The WLAN by default will be mapped to VLAN 1 and will be bridged to eth1 (which is an access port on VLAN 1 by default). In this mode your ISP's modem/router will be expected to serve IP addresses to the wireless clients over DHCP.
