Industrial Wi-Fi Solutions
Industrial Wi-Fi
Reliable, Cost Effective Industrial Alternatives for the Oil and Gas Market.
Reliable, Cost Effective industrial alternatives for the oil and gas market.
Industrial Wi-Fi networks require reliable and secure solutions to support the next generation field area networks that deliver productivity-boosting performance. Demand for diverse, scalable, high-capacity communications infrastructure only increases – even as budgets tighten.
Check out the attached solution paper.
e500 also has the capability to drive an auxiliary device like a Cambium epMP Force 180 or other backhaul device. It can also drive an 802.3af device such as an IP camera, audio detection unit, temerature sensor, etc...
If there is a need for a directional WiFi signal coverage the e501S and e502S offer the same features as the e500, but with higher gain/directional antenna patterns.
