cnPilot e410 and e600 Hardware Installation
The cnPilot e410 and e600 Enterprise Wi-Fi access points support various mounting options for ceiling and wall installations, depending on your deployment.
Ceiling Tile Mount 14mm Wide T-BAR 24mm Wide T-bar 38mm wide T-Bar Wall mount
Can you please point me to the right place to purchase ceiling tile mount for my e600?
What size nut and bolt arrangement can be used on cnPilot e410 bracket please? I am looking to bolt it to the underside of some suspended tray work.
Hi Jairus,
Have you lost the original mounting kit that came along with the unit? or are you looking for additional ones? If yes, what is the quantity you need?
