In the "allow IP" field of the remote access configuration in cnPilot, how can one define that all IP addresses may be used to remotely access the router? In TP-Link we were able to do this by putting 255.255.255.255 in the allowed IP field, but that didn't seem to work for me in cnPilot.
* Have to just enable "Remote Web Login".
* No need to config any ip in "Allowed Remote IP". Leave it default (0.0.0.0).
This will allow any ip address to remotely access your router.
Check screenshot.
Divakar
- remote login.png (5.78 KB)
Thanks, much help
where is that in the cnMaestro config file?
what is the name? is it "DBID_LAN_LOGIN_ONLY=" ?
Below are the config parameters to do this,
DBID_LAN_LOGIN_ONLY=0 (This is for enabling remote login)
WebRemoteLegalIP=0.0.0.0 (This is from any PC, we can remotely access the DUT UI)
Divakar
QUESTIONS:
1. where you see this "DBID_LAN_LOGIN_ONLY="
Is it when you ssh to cnMaestro?
2. where can I download CLI guide of cnMaestro?
tq
Hi
The user can see this parameter in config download file of the device. Please download config file from the device using GUI.
or
Please find the link of the user guide documents for cnMaestro.
https://support.cambiumnetworks.com/files/cnmaestro/cnMaestro On-Premises 1.6.3 User Guide
Please find the screenshot to view the configuration file in cnMaestro
Hi
or
