Default Access Parameters
Default IP address:
cnPilot R200/200P  : 192.168.11.1
cnPilot R201/201P  : 192.168.11.1
cnPilot R201W         : 192.168.11.1
Login:
Username      : admin
Password        : admin
Command Line Access:
Telnet              : Disabled by default, need to be enabled from Web UI.
SSH                  : Not supported.
Web GUI Access:
HTTP              : Enabled by default
HTTPS            : Enabled by default
Default SSID and Password:
Default SSID's in 2.4/5 GHz
CAMBIUM_2.4GHz_MACAddress
CAMBIUM_5GHz_MACAddress
Default Secuity / Password:
WPA2-PSK-AES / 12345678
Default Radio Status:
ON , default SSID will be broadcasted.
SNMP:
V2C Community Strings:  public, private
Change Settings:
Various access parameters can be configured from Web UI under “Administration” Section.
Administration ->cnMaestro             : To Enable Cambium remote management of this device
Administration ->Management         : Following access parameters can be configured from Management section
 Password Reset         : Password can be changed for different user type.
Web Access                 : Web access can be enabled/disabled and Web Port changes.
 Telnet Access             : Enable Telnet, change port no and configure Allowed IP range.
Syslog Settings            : Syslog enabled by default, we can enable Remote Syslog.
