R190V power light flashing
Hi
Does anyone have a full manual for the R190V
I can only find the R200 manual.
Am trying to figure out why the power light would be constantly slow flashing on the R190V after we load our config file on to it.
Also trying to work out why the wifi light is constantly flashing fast when fresh out of the box in default config without any connections. Could be a bit annoying for customers at night and looks like activity when there is none.
   There was an issue with the WLAN LED blinking pattern. It has been addressed and the fix will be available in the next release 4.3.4.
Regarding the power LED there is no known issue, it would blink only during initialization and would be solid green once initialization is complete.
Ashutosh
Here is the Detailed LED pattern for R190 devices
Power
On
Device Power On/Device Ready
Blinking on 10Hz
Firmware Upgrade
Blinking on 1Hz
No IP Address for both pppoe or dhcp mode
LAN/WAN/WLAN
On
Link Up
Blinking as per traffic
Active
Off
Link Down
FXS1/FXS2
Off
Ungregistered
On
Registered
Blinking on 1Hz
In Use
Awesome, Thanks
That LED pattern should be in a manual somewhere
