cancel
Showing results for
Search instead for
Did you mean:
R200 EOL vs R190V
Frequent Contributor
R200 EOL vs R190V
Hi Guys
I noticed the R200 is now end of life and we have started ordering the R190V however I dont see the R190V on the cambium website - only the R190W which doesnt have the voice port.
Can anyone confirm this is just an oversight or is the R190V going to be in limited supply too?
Moderator
Re: R200 EOL vs R190V
Hi Ray,
The R190V is ready and shall be available shortly. This is our latest ATA offerring in 2.4GHz and is not a limited supply product in any way.
thanks
Ashutosh
Moderator
Hi: The R190V is very much present. However, our web page could use some clarity. Thanks for brining this up. We will work on making it clear, regarding the 3 product lines we carry for our home:
R190W: cnMaestro managed Wi-Fi router only
R190V: cnMaestro managed Wi-Fi router + ATA
R200P: cnMaestro managed 2.4 GHz only router with Canopy PoE out
R201: cnMaestro managed, 802.11ac router with ATA
R201P: cnMaestro managed, 802.11ac router with ATA and Canopy PoE out
We bought a good number of these routers, they've been out for what 1year? Where can I find more information about why the EOL?
Aside from the lower tx power (possible gui bug) of the R190V I quite like them over the R200. The reason being the transformer brick that comes with the R200 has no wall mounting option.
Moderator
Tx power( Max 14dBm,   the config parameter  in GUI) and Effective the  Isotropic Radiated Power( 20dBm) of  r200 and r190  are equal but r190  has new hardware/chipset.
Regards,
Niraj
Occasional Contributor
Will the 190 be getting a power out option?
Moderator
Hi
R190 PoE out option is not part of our roadmap.
Regards,
Niraj
Moderator
Hi All,
r200P(PoE out model) is not part EOL r200 device. Just the Non-PoE-Out models of r200 are part EOL.
Regards
Niraj
