cancel
Showing results for
Search instead for
Did you mean:
Restart for each configuration change in cnPilot R2XX
Occasional Contributor
Why do we have to restart cnPilot R2XX when a change in its configuration is implemented? Are the changes implemented regardless of whether the device is restarted? What does the fact of having to restart the device after every configuration change? in some cases it is not operational.
Thank you very much.
Regards
1 REPLY
Moderator
Re: Restart for each configuration change in cnPilot R2XX
Hi
As per current software design, it is required to reboot device whenever there is any changes  in configuration.   We are planning to implement Save and Apply  functionality  in upcoming release.
Regards,
Niraj
