ssl_not_check_server
Hi
how can set ssl_not_check_server parameter to 1 on provision, becase i saw if this parameter is on, i don't need upload the Certificates CA's to router or you know any method to upload from provision a  CA's Certificate.
Thisi parameter is enable by default if vendor are QTECH. I saw in provision script
  • How can set ssl_not_check_server parameter to 1 on provision, becase i saw if this parameter is on, i don't need upload the Certificates CA's to router
          >>> There is no such parameter in our R-series device.
  • You know any method to upload from provision a  CA's Certificate.
        >>> Please use GUI option method to upload a  CA's Certificate for the  Https provision.
 Regards
Niraj
