Force 300-25 as a standard WIFI. It is possible?
Does Force 300-25 supported Standard WIFI setup?
I'm planning to cover wireless access in the airwell for a condominium (16 levels).
Place on the top/bottom of the building and direct it to the airwell.
10 degree coverage would be ok as the airwell is about 10x5 feet only.
I tried Force 180 and it works, however it only support 5Ghz.
I'm wondering if Force 300-25 can do the same.
I guess with the force 220 there will be no problem.
regards.
