GPS format in CnMaestro
Guys ...
I am trying to understand what is the format of the GPS coordinates that are accepted in the CnMaestro when I am going to add a new tower / site.
If I copy the coordinates of the link planner or from ePMP they are not accepted in Maestro. What is the cause?
I can only add a location when I search for the address manually, but this takes a lot of time.
Decimal degrees but don't include the +  for non-neg numbers.
If the radio was located at  +34.1991°   by -91.83009°  you would enter it as:
34.1991
-91.83009
If your radio has GPS then it will auto populate that field in CnMaestro and if you enter the cords in your non-GPS radios they will also auto populate that field in CN Miestro.
