Hi Team,
We have 600+ device on cambium elevate and also have some problems and need help
1.Main problem is update on xm device (not all xm device have this problem )
When try update xm device from rc3.3,3.3,3.4 , device get freeze in different phase of update progress .After reboot device run with old fw or become 10mb/s
In most case double reboot help . In 99% tftp recovery helps for recovery using elevate fw.
Device uptime 4min-10hour. Also are some device what always ask for reboot in cycle.
2.Lan drop on Locom5 (xw and xm mostly on xw) and on Beam19
On locom5 lan drop average 2-8 hour after restart work`s few four and drop
Update to 3.41 and 3.5 ,reset to default , recovery witch elevate fw don’t help
On beam 19 lan drop after 3-7 day update to 3.5 like it helped but when try restore witch json config get networklanspeed error show what parameter need add to config.
