I Can't put the geographic coordinates in Elevate 3.5 firmwares, if I inform -17.12345 when I exit the field the decimal was gone, only -17 stay in the field
Thank you for your feedback.
This is known issue in 3.5 FW.
It is already fixed and fix will be delivered in 3.5.1 soon.
Thank you.
