Defect Fixes (System Release 3.2.2)
Tracking |
Description / Workaround |
13675 |
[ePMP Elevate] XM NSM5 in NAT mode may reboot with an OOM (out of memory) reason when upgrading from one ePMP elevate software version to another. This is not 100% solved but occurrence rate has been drastically reduced |
13608 |
Occasional false radar detections on ePTP links running 40 MHz channel when there are reflections in the environment |
13600 |
Uplink TCP throughput is lower than expected in 3.2.1 |
13274 |
[ePMP Elevate] On an AP with many SMs, ePMP Elevate subscribers may deregister with reason “Reason: 32 (NO ALLOCATION ON AP)” |
13261 13654 |
SNMP deamon crashes or causes high CPU utilization resulting in unexpected behavior such as management interface not responding or radio rebooting |
12824 |
On rare occasion in TDD mode, when an SM disconnects from the AP, it may not reconnect when WPA or RADIUS is used |
10726 13841 |
ifTable entry not created for second Ethernet port on the SM |
Known problems or limitations (System Release 3.2.2)
Tracking |
13846 |
It is not possible to change the SM’s Network configuration from Bridge to Router mode via SNMP. |
13825 |
GUI indicates In-Service-Monitoring DFS status for 5-10 seconds after switching to non-DFS channel. |
