Defect Fixes (System Release 3.4.1)
Tracking |
Description / Workaround |
14598 |
Max Registrations Allowed is reset to 10 after AP Lite upgrade from 3.3 to 3.4 with Full Capacity License Key Entered |
14591 |
Unable to login via GUI after changing radio’s IP Assignment using Firefox |
14589 |
[Elevate 5GHz] Software Update failed for 5GHz Elevate Devices on cnMaestro |
14337 |
Unable to set Country Code after switching from SM to AP mode |
14482 |
Force 180/200 exhibiting reboot with 3.3 FW installed |
14399 14360 |
Error message is displayed upon Link Tests start |
Known problems or limitations (System Release 3.4.1)
Tracking |
14611 |
[Elevate 2.4] "SM disassociated from AP. Reason 32/33/48" during Stability test {XW} |
14613 |
Incorrect processing status on GUI when Link Test is failed |
14609 |
Home User erroneously able to configure network configuration |
14614 |
The Ping utility does not show latency if use less than 8 of 'Buffer Size' |
14612 |
[Elevate 2.4] Link Test is not completed properly |
