Dear Sirs,
We have Two Epbx with Same model KX-TD100D installed at two different location with 1 km approx distance between them a Highway is passing between two location, hence we want to make connectivity of Two epbx, hence people from both side can communicate through epbx.
Following would be connection :
KX-TD100D PANASONIC EPBX
Adding a PRIMARY RATE INTERFACE MODULE KX-TDA0290, 30-CHANNELPRI CARD (AS A 30-DIGITAL CO LINE)..Need to do QSIG programing TO BOTH EPBX
PRI WILL NOT BE ABLE TO CONNECT DIRECTLY WITH ePMP 1000 integrated radio Antenna 5 GHz.
So, We have to add E1 OVER ETHERNET SWITCH between PRI CARD & ePMP 1000 at both side.
Now let me know this can make both epbx run with each other, above pri card can transfer total 30 line at a time talking with each other from both side.
Practically PRI TO PRI making wire connectivity it can be done easily and it works, now we want to know whether providing Wireless bridge using e1 over ethernet & ePMP1000 it is possible?
Awaited to hear from you. We need a solution from your end.
THANKS
YAGNESH DARJI
