I keep having several 450 ap's switch from power port gps source to onbard gps source sync. However its not losing sync on the power port ap is still showing its has sync there.
what would be causing ap's to switch from power port to onboard sync?
fsk ap's using the same sync source are having the issue only 450 ap's
I'm more curious to why this happening as the problem started once we went to 15.1.1 beta had some issues. rolled back to 15.03 and now half of our 450's keep rolling to onboard sync while the other hold sync over power through sync injectors from packetflux.
I didn't understand if this is causing you interruptions in sevice, or if it's just a curiousity.
Packetflux is a third party device, and while we recognize the value in having ecosystem partners like them, we haven't confirmed or validated these devices with the latest software.
well we had 0 issues with 450 ap's chaning sync source unti we tried 15.1.1 firmware. before that date they always used gps sync though sync injector. once we updated after being on for couple hours units would roll to internal gps. even though they never lost gps sync pulse on the power port.
I want to know why this is happening becuase we have 450's Ap's that are stacked so some units don't have a clear view of the sky and could cause us issues.
