Yes - quite a few requests here but i will do as many as i can!
I misread the MIR on one of the SMs (it is being used as a backhaul to another access point). The MIR for that radio is/was actually 100000/100000.
Thank you for the answer on MCS0.
here are the four sectors:
west
access point
tdd
united states
range unit - miles
maxregs=30
maxrange=20
autochannelsection=disabled
channelbandwidth=20
frequency 2437 (wanted to use 2412 but one customer will not connect on that channel)
frequency reuse=front sector
altfreqcarrier1bandwidth=20mhz
altfreqone=none
altfreqcarrier2bandwidth=20mhz
altfreqtwo=none
transmitteroutputpower=27
antennagain=8
targetreceivelevel= -53
downlinkratio=75/25
framesize=5ms
downlinkmaxrate=mcs15/64qam5/6
managementtrafficrate=mcs1
colocation mode =enabled
syncsource=gps
syncholdtime=3600
north
access point
tdd
united states
range unit - miles
maxregs=30.....(this was incorrectly set for 60!!) now fixed.
maxrange=20
channelbandwidth=20
frequency 2462
altfreqone=none
altfreqtwo=none
antennagain=8
targetreceivelevel= -52
downlinkratio=75/25
framesize=5ms
syncsource=gps
syncholdtime=3600
** i do note the sm receive level is off by one db. is that an issue?
** i see that is important per the notes section. i will change. it is now -53
south
access point
tdd
united states
range unit - miles
maxregs=30
maxrange=20
channelbandwidth=20
frequency 2462
frequency reuse=back sector
altfreqone=none
altfreqtwo=none
antennagain=8
targetreceivelevel= -50 (changing to -52)
downlinkratio=75/25
framesize=5ms
syncsource=gps
syncholdtime=3600
east
access point
tdd
united states
range unit - miles
maxregs=30
maxrange=20
channelbandwidth=20
frequency 2412
altfreqone=none
altfreqtwo=none
antennagain=8
downlinkratio=75/25
framesize=5ms
syncsource=gps
syncholdtime=3600
** i got an error when changing the sm receive level to -52 on the last three sectors but the validation error message was blank. (all it said was validation results:)
** looks like i must move them all to -52 in order to not get that error.
I did a spectrum analysis of the area when we upgraded to four sectors. I had everything turned off at that time. I will attach.
Unfortunately I rebooted all the access points when changing the sm receive level so all the stats have been cleared. I will retest the one known "weak" sm. I am waiting to hear from my tech as to which other customers on that sector may have had problems.
I just ran a 10 second link test on the radio in question.
Downlink
32.092 Mbps
Uplink
0.962 Mbps
I will attach the performance page for the SM
the sm in question is 3f:78
I do appreciate your helping us with this.
