I have a new AP that has been sitting on my shelf for a little over a year. It was at software release 2.3.x. I upgraded it all the way to 2.6.2 via stages. I then put my standard configuration on it which includes a management vlan. Once this is done, I lost all access to the radio even though I put the matching VLAN on my NIC. I then attached to a switch and had the same problem.
I factory reset the radio and moved it to 2.4.3 and put my standard configuration in it. The radio worked fine. I tried 2.6.0 and 2.6.1 as well and they worked fine. As soon as I put 2.6.2 on the radio I lost access again.
Symptoms:
1. Can ping the IP
2. Cannot telnet or SSH to radio (Get connection refused)
3. Cannot open web browser to radio (does not matter the browser). When I telnet to port 80 I get connection refused.
My question is has anyone else experienced this issue with 2.6.2?
Gilbert
