2 APs 1 Antenna
has anyone ever tried and successed at this?
we use conectorized 2.4 APs 90 degree sectors, I’d like to simply add a second AP with a T connector if it is SAFE but i can’t find any information out there that says one way or another. I would assume it’s not OK, but just thought I’d Check here
i planned on using 2415 and 2457.5 for the same antenna setups
we have limited space were these access panels are and have to go thru a mess of paperwork to change our antennas, attaching an extra AP to an antenna would be considered “maintenance” in our contract and i can do any time.
You can do it if you use a Diplexer
http://www.rflinx.com/products/filters/2400/diplexer/
