Any one used 2 CMM’s on the same POP…
any issues ?
any special config needed
Yes. We are using 2 CMM’s at 2 different locations. You need to set up one as a master and one as a slave if you are going to connect the 2 CMM’s together. If not, the set them up as usual and use seperate GPS units. They work great.
