Dear Cambium, I think it’s high time to work on the quality of the screws that came with the switch 2052. I used a screwdriver set to no impact and speed “1”. It tightened 2 screws.
I would like to add that the netgears mounted next to it had no problem with this type of assembly, they additionally gave more screws and thanks to them we were able to mount the cambium.
