We received a shipment of 7.2.9 backhauls today. I thought that Moto Recommended that we do not upgrade above 7.14 on Backhauls? Also I noticed the following settings:
Hardware or Software
Bridge Enable or Disable
Does the hardware scheduling give the module the ability to adapt from 10M to 20M incase of interference? What is the bridge enable disable good for?
-J
Anyone?
The software upgrade is only in regards to co-located BH’s.
Turn on Hardware Scheduling.
Canopy networks are bridged networks so enable bridging. If you were running a routed network with routers at your towers, you might do something different.
