I have a good link (I believe) 1034 RSSI -63dbm jitter=9
Master side Downlink Data is set to 75%
Link test is as follows:
Stats for LUID: 2 Test Duration: 5 Pkt Length: 1522
Downlink RATE: 10810982 bps
Uplink RATE: 1093632 bps
Downlink Efficiency: 97 Percent
Max Downlink Index: 100
Actual Downlink Index: 97
Expected Frag Count: 105576
Actual Frag Count: 107892
Uplink Efficiency: 29 Percent
Max Uplink Index: 100
Actual Uplink Index: 29
Expected Frag Count: 10680
Actual Frag Count: 35982
When I do a speed test from Slave side to master side I only get about 2.3Mb/s. Slave and Master are both plugged into a switch along with laptops running raccoonworks speedtest software. There is nothing in between that is throttling throtling the speed. I used to get 7-8Mbp/s. I can’t figure out what’s going on. Any help would be appreciated. BTW, both master and slave are ver. 7.1.4
Your uplink efficiency is poor at only 29 and the jitter is high at 9. Are you using reflectors? If not I suggest using them, if you are using them then I suggest you re-align the link.
