As far as I read in the 28 GHz specification Wave ™ C200 CPU supports 24.25 to 29.5 GHz.
I have two questions,and there may be ideas
Can a CPU be connected to a CPU to make a PTP connection?
Will there be a version that supports 24.05 to 24.25 GHz.
In many regions of the world it is a free band.
Regards
Too bad. You are finally able to answer the Ubiquiti Air Fiber 60 LR which works one mile more.
With a capacity of over 1Gbps.
The unlicensed band at 24 ghz is what these CPUs I asked for have all the hardware benefits, it’s just a matter of whether you recognize it or not. Will it be done by software.
Of course at 24 GHz you can go much further than at 60 GHz.
That is what is currently missing
I’m sorry you don’t recognize that!
“May the force be with you”
Best regards
