We have been running into a problem with the 3.6 450 radio's slowly losing signal and will eventually come up with a "Radio not calibrated" in the GUI. We have to go to the location and swap out the gear then call up cambium to get them reset and put a license key put back on them. Not a super big deal just want to keep my network as healthy as i can. For the most part i have really liked the 3.6 line and haven't had issues with them until just recently. Seems like it started up roughly a month ago and i have had at least 5 of them so far and found 1 in the field before it completly dropped. I don't see anybody else with this issue on the forms, is this a known problem?
I have not heard of this before. Can you describe "slowly losing signal" a bit more?
What kind of key needs to get put on? A throughput key?
Well we had a customer that when first installed had a signal of roughly -63 with a 8x6 modulation that degraded to a -72 8x2. She called in saying her connection was getting poor, so we swapped her equipment out and she is currenttly at a -64 8x6. No change in aiming or what AP she is connected to.
And yes when reset they are getting reset to 4meg when they need to be either 10 or 20's.
Recent I still have this same problem PTP450 3.6 Cambium radio unit showing an error message of Radio not calibrated.
Please help me how can this problem be solved?
- Radio not calibrated.docx (177 KB)
@KOwopetu123 wrote:Recent I still have this same problem PTP450 3.6 Cambium radio unit showing an error message of Radio not calibrated.
You'll need to open a ticket with Cambium support to resolve this issue.
