Looking for some USB dongle CPE for 3.65…anybody know of any or had experience with any?
We have just started testing some USB dongles in our network. I have connected at 2.5 miles from our tower LOS with 5x4 (we are using 10 MHz channels and 55/45). You can check them out at http://www.celalink.com/
We are testing to use them as a “hotspot” type product in downtown areas and business areas close to our towers. I can’t say whether they have a negative affect on our network since we have just started testing. I would not expect a lot from them inside unless close to your tower. They are also not a replacement for a traditional fixed cpe deployment in my opinion.
cshorenc wrote: We have just started testing some USB dongles in our network. I have connected at 2.5 miles from our tower LOS with 5x4 (we are using 10 MHz channels and 55/45). You can check them out at http://www.celalink.com/
We are testing to use them as a "hotspot" type product in downtown areas and business areas close to our towers. I can't say whether they have a negative affect on our network since we have just started testing. I would not expect a lot from them inside unless close to your tower. They are also not a replacement for a traditional fixed cpe deployment in my opinion.
Is it possible to operate this Stick in ETH-CS mode? I've a stick from AWB which works only in CS-IP mode so I cant
use it with PMP320 in Layer2 mode.
were can you buy these from? they haven’t returned my e-mails or phone calls I’m intrested in there indoor router CPE, we have a lot of homes within a half mile of our towers and have had a good luck with the 900 mhz indoor SM
I got a quote from the manufacture… we gotta buy 500 at a time so if anyone wants some give me a yell, we only want a few hundread
mgthump wrote: I got a quote from the manufacture... we gotta buy 500 at a time so if anyone wants some give me a yell, we only want a few hundread
What's the price?
