30° sector for 450i 900Mhz ?
Anyone found a good 30° dual pol 45° slant sector for 900Mhz ?
Any reason this panel antenna -  KPPA-900DP-FP  38° Azimumth / Elevation 13.5 dBi  27dB f/b -  wouldn't work in a pinch ?
Those KP's that you mention work great. We actually ended up swapping out a number of sites that were using 60deg antennas for those.
Are you folks using these for 8 sector PMP450 900Mhz deployments on a single tower?
If so, do you mind elaborating slightly on your setup?  I'm very curious how I could maximize what I have and expand if necessary...
Sweet ! Thanks !
I'm not... I just prefer the 30deg panels over the 65deg sectors to reduce noise. Most of our 900MHz sites only have 1 or 2 radios.
