I have a 300c aka CSM in TDD PTP as slave to a 1000GPS. I'm trying to figure out if I need to climb Tower A and replace the CSM or if there is a known issue with AC CSM in PTP with N 1000GPS and I should climb Tower B and replace the 1000 with a 3000L .
So during a break in a storm several months ago we replaced a dead F200 on tower A (it was the slave PTP to a 1000gps). Turned out the new F200 had the 10dB chain imbalance defect and the window in the storm was about gone, I didn't have another one on hand.. it was working, mostly, we left it.
Fast forward to about 2 weeks ago we finally got back to this tower and replaced the defective F200 with a CSM in a RF Elelments Horn. So now 300c slave on tower A , 1000GPS master on tower B. Everything looked good.
Then tonight the 300c suddenly started randomly rebooting (says Hard Reboot on counter). Longest it will stay up so far is about 34 minutes.
The 300c was running 4.5rc52 (or whatever the current one is) and the 1000 Master was running 4.4.3. So I loaded 4.4.3 on the 300c and waited for it to reboot itself. It reboots itself and comes back up with 4.4.3.
Just minutes later it reboots itself again. I load 4.4.3 up again (so both banks will be 4.4.3) and wait. About 30 minutes later it reboots itself again, comes back up 4.4.3 in both banks. Then 17 minutes , reboots again. I load 4.4.1 and wait for it to reboot, shake rinse repeat , it and the 1000 Master are currently running 4.4.1 it's still rebooting randomly with 34 minutes currently the record for longest it's gone without a reboot.
I also tried changing the frequency to a non-dfs frequency.
Checked to make sure the SA wasn't running (it wasn't)
Locked down the MCS to 1 less than it was doing (100% MCS7 - 64QAM 5/6 locked it to 6 - 64 - 3/4)
Disabled remote management
Soft rebooted it
Finally drove out and replaced the power supply (it was being powered with the supplied cambium PS)
There is nothing in the logs , I downloaded a support file.
