Using layer 2 mode:
The Ap is exposing only 1 interface to snmp : Interface 3. This interface is not reporting the actual throughput and other stats the AP is doing. This is kind of important in terms of being able to monitor these new radios before we can deploy them. Has anyone found a workaround for this or know of any impending fix? Any info would be helpful
What program are you using to monitor the AP?
we have custom snmp polling scripts that store the data to RRD
