rch68
(rch68)
#1
Is it possible to use the timing from a 450AP (rj11) set to ouput sync and input this into the 450i , which is an rj45 connector pins 7 and 8 ?
I have tried this but doesnt seem to detect pulse.
I can use the output from one 450i to another with cat5 cable and that works.
rch68,
We have an open issue for this problem between 450i and 450's and hope to have it corrected soon.
Best,
Cambium Jonathan
FVI
(FVI)
#3
Update on this?
I would like to send sync to a 450i AP from a 450 AP using the timing/ugps port.
Currently, my 450 AP's sync source is Power Port via CMM Micro. Is this possible?
