Hello, The company I am employed by bought the 450m 3ghz kit from a supplier. I was hooking up the cmm5 module for a test and notice they sent a 600w 56vdc HLG-600H-48A unit to power the cmm5. The cmm5 cannot power the 3ghz 450m correct? If so is there anyway to distribute the dc this gives to 4 aps and the cmm5, or do i need to buy the N000000L054B ? Which the vendor did not quote or supply.
The cmm5 has a power injector to put power up the cable. It does both 802.3at and cambium passive. Just have to configure it
