4600 Poor downlink throughput
We are seeing downlink throughput tests way below what the link test is showing. The link is 4.15 miles and the noise at the AP is higher than typical for 6 GHz, so those may be the issue. But, it’s an AP with only 1 SM and the customer was gone during the day today so I ran multiple tests on multiple channels. AP & SM are both on 5.10.0 software. RSSI is -73/70 Throughput tests are Mikrotik speed tests on hap ax2 at customer to 4011 at tower. In general, on 80 MHz channel downlink on link test was 350-450 Mbps. TCP downlink speeds were 75-110M. UDP downlink was 200-250M. In the uplink, both TCP and UDP speeds were right on the link tests. Results pasted below are from the best channel combo, which was asymmetric 80/40M.
Link test:
    tcp-download: 122Mbps local-cpu-load:17%
      tcp-upload: 40.2Mbps local-cpu-load:3% remote-cpu-load:4%
    udp-download: 237Mbps local-cpu-load:11% remote-cpu-load:16%
      udp-upload: 36.5Mbps local-cpu-load:2% remote-cpu-load:2%
I am seeing 10-12 % retransmissions in the uplink, which could explain part of the discrepancy. Only 1% retrans in the downlink.
